- colliehaulerExplorer III
whjco wrote:
That would be my choice as well with the V-10 engine.
I can't speak to the Express, but I had a Ford E350 that was a great tow vehicle. - whjcoExplorerI can't speak to the Express, but I had a Ford E350 that was a great tow vehicle.
- carringbExplorer
fitznj wrote:
If can you can hold out for a slightly newer one (2010+, with the 6L90,
Can you elaborate on this? I'm selling my 2008 van and looking for
a newer one next year; Your comment piqued my curiosity.
thanks
BTW - I agree with your comment in the shocks - the standard ones
really can not cope - upgrade when you need new ones.
2010 was the first year for the 6L90 in the Express. The 4-speed just wasn't a good match for the 6.0. The 6-speed on the other hand, seemed to have been designed with the 6.0 in mind. The ratios are close enough together to keep the motor making enough HP. With the 4-speed, it would plat the "lose speeeeed DOWNSHIFT gain speeeeed upshift.... lose speeeeed DOWNSHIFT" game.
That's really the only improvement, so there's not a whole lot to be gained going brand-new, other than being able to find one in good shape. The Express interior doesn't hold up well in rental-duty. Lots of small things get broken. - LwiddisExplorer III doubt a van would have more crosswind issues than my Tahoe or a Suburban for instance.
- MARK_VANDERBENTExplorerMay need New exhaust manifold gasketsand upgraded bolts. Had that done on my truck and was not to bad.
- MARK_VANDERBENTExplorerThanks. The one I'm looking at is cherry . Very clean just rust in front edge if the hood. Bug shield may be in future. It has 330,000 miles like my suburban, and is a one owner and they took care of it meticulously. Checking to see if it has any rebuilt trans or not?
- fitznjExplorerIf can you can hold out for a slightly newer one (2010+, with the 6L90,
thanks
really can not cope - upgrade when you need new ones. - carringbExplorerThe Express 3500 should be a great match for your trailer.
Yes, the 6.0 Express will easily match the 5.3L Suburban for fuel economy.
The 6.0 isn't a torque monster, so you do have to spin in up to make power. Also, with the 4-speed, grade-ability isn't great (tall gearing, low stall speed in the torque converter). Max launch grade with your trailer will be about 15%.
If can you can hold out for a slightly newer one (2010+, with the 6L90, you'll have a much better powertrain for towing.
#1 improvement you can make is replacing the worthless OEM shocks with good monotube, like Bilsteins. Otherwise it'll wallow like a drunk pig when it's loaded.
And yes, 100% of White Express vans will eventually start peeling their paint. The colors don't seem affected. - MARK_VANDERBENTExplorerThanks for those mpg numbers. Those are right at my suburban 5.3 are. You sure you have a 6.0????
- fitznjExplorerOne data point:
Empty local driving - 13-14 mpg
Empty highway - 17- 19 mpg @65mph
Towing - 11-12 mpg
One odd thing I found when I went from a 5,200lb camper to a 3700 lb camper is
that my fuel consumption stayed EXACTLY; My conclusion is that trailer frontal
area has the biggest impact on fuel economy;
I would expect your fuel consumption towing would be closer to 10MPG as you
are towing approx 1,000 lbs than my heaviest camper.
44,055 PostsLatest Activity: Dec 23, 2025
