larry_barnhart
Mar 06, 2017Explorer
djgarcia wrote:DWeikert wrote:djgarcia wrote:
When you have Transfer Flow install an auxiliary fuel tank they recalculate your new auxiliary tank to your current fuel gauge on your dash. i.e. full= 60 gal. 3/4 tank= 45 gal. etc etc etc.
Maybe for your truck. Based on my research GM's computers can only be set to a tank size GM installs at the factory (26 or 34 gallons for my year). Supposedly there's a way to use EFI Live to edit the tables and re-calibrate the fuel level sensor voltages so your fuel gauge displays accurately. Otherwise gallons used would be accurate, but gallons to empty and the gauge itself would be significantly less than accurate.
You are probably right. It dosen't appear that it would be a good idea for you to install an auxiliary fuel tank.
We have this issue on the 55 gal inbed tank for the correct guage reading but the truck has fuel used and it is correct. Just a toggle switch to change tanks.
chevman
44,068 PostsLatest Activity: Apr 17, 2021
