- BedlamModeratorI plated both sides of the OEM hitch pin hole when towing my toy hauler. The same egging also happened as described above.
If you apply simple physics of using a lever resulting in torque multiplication, you will see that you need to drastically derate an OEM with an extension or you will be severely overloading it.
My F250 with SuperHitch and SuperTruss had no issue with an 8000 lb enclosed trailer. Although I have since sold the Ford to upgrade to a Ram 5500, I still use the same SuperTruss with a new SuperHitch. Neither receiver or extension are showing the wear my OEM did without extension when pulling my previous 11,500 lb trailer.
Even going up and down driveway entrances would be problematic with a longer tongue and no extension on the receiver for us. I would hate to think what would happen if we traversed a wash to get to campsite. We don't four wheel with our trailer, but do camp in primitive areas where a long tongue would make contact with the TC underside. - PRodacyExplorer
Vinsil wrote:
PRodacy wrote:
Everyone seems to say that the factory hitch is too weak to handle the extension, but where is any evidence? I've never seen any specs on it, never saw evidence of a failure, or any engineering calculations. Maybe the aftermarket ones are stronger, but is there any evidence that they're not expensive overkill?
My neighbor has a 2012 Ram 2500 and pulls a 38 foot Weekend Warrior with a 1800 lbs tongue weight. He uses a WD setup and in less than 3 years has completely egged out his factory hitch. It is ruined from that weight and stress. So, having seen what happens to a factory hitch that is overloaded and abused....I'd wager it is not an expensive overkill if you lose your trailer doing freeway speeds.
But that would be the 2 inch hitch, not the 2 1/2 inch hitch, right? I suspect that would happen with any 2 inch hitch no matter who made it. - VinsilExplorer
My neighbor has a 2012 Ram 2500 and pulls a 38 foot Weekend Warrior with a 1800 lbs tongue weight. He uses a WD setup and in less than 3 years has completely egged out his factory hitch. It is ruined from that weight and stress. So, having seen what happens to a factory hitch that is overloaded and abused....I'd wager it is not an expensive overkill if you lose your trailer doing freeway speeds. - PRodacyExplorerEveryone seems to say that the factory hitch is too weak to handle the extension, but where is any evidence? I've never seen any specs on it, never saw evidence of a failure, or any engineering calculations. Maybe the aftermarket ones are stronger, but is there any evidence that they're not expensive overkill?
- burningmanExplorer III think you're ALL crazy!
I hate extension hitches no matter how stout they are. The laws of physics cannot be broken; putting your hitch that far behind the axle gives your trailer a lot more leverage against your truck.
I tow a heavy (sometimes its 10,000 pounds) trailer with a dually carrying an 11.5 camper.
Rather than run one of those insane long hitches, I stretched my trailer tongue to reach the hitch right at the truck, under the camper. My truck is a 4WD (so it sits a little high) and I have the camper raised a few inches off the bed floor, and that buys me enough clearance. I've driven thousands of miles with no trouble.Yes, you have to watch your approach angles, but it's worth it.
There is absolutely NO way a truck with a fairly heavy trailer can drive as well or be as safe with the hitch three or four feet further behind the axle, regardless of how solid the hitch itself is.
Anyone who is capable of fabricating a hitch extension, or is going to pay someone to do it, should consider doing it the other way. Bring the trailer up to the hitch! - ticki2Explorer
Kayteg1 wrote:
I will have to take a picture to show my setup. What makes it different is that I have truck frame sticking long past the bed and existing hitch is having just cross bracket to bolt it to.
Some pictures would be very helpful . - Reddog1Explorer IIBuzzcut1, please repost your truck hitch photos. Is it a factory hitch? Is ti a 2-1/2 inch?
- Buzzcut1Nomad IIthis is my set up, towed a 7000 pound trailer full of horses to the show. 48" extension
- Kayteg1Explorer II
stevenal wrote:
Kayteg1 wrote:
I add question.
SuperTruss from what I see on the site works only with SuperHitch.
I do have 2.5" receiver on my truck and would like to utilize that for up to 7000lb trailer and from what I measure I could use 5 foot extension.
Anybody found easy solution ?
I used to run an 18" extension with about a 3" drop draw bar with my old truck and boat. I left a few scrapes in the asphalt near the bottoms of driveways and similar grade transitions. I can't imagine a 5' extension working anywhere in this regard.
I think this is 3" drop that made the scratches.
My hitch is high enough that makes it difficult to step on.
All add-on hitches go under the bed to bolt at the bottom of the frame, what is a weak point.
I had bolts popping out on such hitch on my motorhome and that is why I hesitate to consider this option.
I guess it is time to start shopping around for 2.5" square tubing. - stevenalNomad II
Kayteg1 wrote:
I add question.
44,066 PostsLatest Activity: Apr 15, 2026
