I need some info from those that have a extended receiver hitch on your pickup. I need to move mine 24" to the rear, I will be pulling a 29' travel trailer with the hitch...thanks
Factory stock truck hitches are not meant to use a 5' extension, or for that matter even shorter extensions. A 5' extension greatly reduces the amount of tonque weight that can safely be towed. Reese makes a (2 1/2") 42-48" long extension but I would not recommend using that on a factory truck hitch. Its a decent extension if you upgrade to something like a Reese Titan hitch and tow a smaller trailer.
