I need some info from those that have a extended receiver hitch on your pickup. I need to move mine 24" to the rear, I will be pulling a 29' travel trailer with the hitch...thanks
If you compare the SuperHitch to other aftermarket receivers, you will see how much stronger it is built and how many more attachment points there are to the frame. There are plenty of competitors that have high capacity receivers but none that have the required capacity with an extension in use.
