haste_maker
Sep 08, 2015Explorer II
Extended Receiver Hitch
I need some info from those that have a extended receiver hitch on your pickup. I need to move mine 24" to the rear, I will be pulling a 29' travel trailer with the hitch...thanks
Kayteg1 wrote:mkirsch wrote:Kayteg1 wrote:
I add question.
SuperTruss from what I see on the site works only with SuperHitch.
I do have 2.5" receiver on my truck and would like to utilize that for up to 7000lb trailer and from what I measure I could use 5 foot extension.
Anybody found easy solution ?
Easy solution is install a Torklift SuperHitch. Your factory hitch will not handle a 5 foot extension with 7000lb trailer.
You don't need a 5 foot extension anyway. There is no camper that extends 5 feet past the rear of the truck. At most you need 4 foot. As long as the ball is even with the rear of the camper, you will not have trouble.
Even with 4 foot, best option is to install a Torklift Superhitch. Very different from my situation where a few inches would be enough.
My truck originated as cab & chassis and I don't think any of Superhitches will fit.
I converted it to regular bed (actually I have Dodge bed on Ford and the frame stick behind the bed, where factory hitch bolts to.
I strongly believe my 2.5" receiver is stronger than Superhitch, but being unique is not making it easy and I don't see 2.5" supertruss anywhere.
The extra extension length might be needed since I put my TC with about 16" space on front of the bed for carrying junk.
