We have found ourselves in a spot where we are going to have to live in our camper for a bit and need to purchase an extension cord that will reach the closest power. I am looking at a heavy duty 100...
15 and 20 amp cord connectors are quite often miss stated. The 15 amp has parrallel phase conductor blades where the 20 amp has the neutral conductor blade perpendicular to the phase conductor blade. The blades are the same size between the 15 and 20 amp.. Ground conductor can be reduced in size which is very common on most electrical cables.
