Miguel951
Aug 14, 2023Explorer
Extension Hitch Question
Hello! Back again for assistance with my setup. With the camper on the truck, I'm 29" exactly from the center of the pin on the hitch to the door of the camper. The question is: what is the best way to get there?
-I'm ok with part of the trailer going under the camper, just need to remove the jack and install one that I can tilt in transit.
- I have a 2" hitch receiver
- Trailer is a 12' single axle, carrying a UTV that fits snugly in the trailer. Approximate tongue weight of 600lbs (but will be taking to scales soon to get the exact weight).
-I do have a weight distribution hitch that I can include, would prefer not to use it since I'm using airbags and height can vary. (even though I can be exact, I would prefer not to mess with it).
I've seen 18' extensions and a hitch insert that can get me to 24" but they are rated at 3500 LBS and TW 350 LBS. I've also seen a 16" hitch ball mount rated at 6k LBS (assuming 600 LBS TW).
If I use the 16" extension only here are the dimensions I would be left with, not sure how safe I can turn with this setup.
I can provide more information if needed.
