mogman
May 01, 2013Explorer
You state your trailer weighs 3100 lbs. dry.
No one tows a "dry" trailer.
You may have to add the weight of the battery, propane tank(s), possibly the awning. Also add in food, pots and pans etc. personal supplies, clothing etc, water and so forth. Also weight of contents of holding tanks.
I'm betting it will be close to 4000-4500....or more?
What is the stated gross (maximum)weight of the trailer? Best to load up the trailer as if you were going on a trip and hit the CAT scales and get some accurate weights and go from there. Your weight distribution hitch could weigh 75+ lbs. That is weight that will be subtracted from the vans carrying capacity.
Do you have a "tow package" on the van? At the very least install an extra trans. cooler and the required brake controller.
