Msu50000's avatar
Msu50000
8 years ago
Exterior Coax Connection Not Working
Football season! Camping over Labor Day weekend and with the weather not going to cooperate thought we'd get some use from our outdoor TV set up.
First, with TV set up inside and connected to TT we were able to pull in more than 40 channels. There's a small panel near the TV inside that has a Satellite output and an OTA antenna output. There is a button on the small panel that the dealership told me is a booster for the OTA antenna. TV is connected to antenna with the booster turned on when we pull in 40+ OTA channels.
So I took the same TV and put it outside and connected to the exterior antenna jack, left booster on inside. No channels were coming through. Ran auto scan 3 times with booster on and off. And just to clarify, this is not the "cable in" jack on the other exterior side of the trailer that i would use to connect to a CG or park. Any ideas on what could be wrong?
