atreis
Aug 16, 2015Explorer
There are pros and cons to each. Which you pick is up to you. (My trailer is 7 years old, and has laminated walls, roof, and floor. It has no delamination, no leaks, and no issues with any of those items. I can, and do at least twice a year, walk on the roof.)
Pros for each:
- Aluminum weighs less (all else being equal).
- Aluminum costs less (all else being equal).
- Aluminum can be replaced, but it's most likely not a DIY task.
- IMO, aluminum usually looks nicer in older trailers.
- Laminated can be significantly better insulated.
- Laminated is stronger (all else being equal) - the wall itself is structural rather than just the framing.
- Laminated can look nicer when new/clean/maintained.
Cons:
- Aluminum dents very easily, and can't really be undented.
- Aluminum can make it hard to detect a leak within the walls until it gets to the point of the framing having rotted.
- Aluminum trailers are usually insulated with fiberglass batting, and there can be significant gaps in the insulation due to quick/low quality construction, as well as settling within the walls over time.
- Laminated will delaminate if there is a leak. If you notice and fix the leak quickly this isn't necessarily a serious issue, but if not it can be.
- Laminated trailers can be repaired but it's costly, difficult, and visible.
- Seems harder to maintain the good looks of laminated walls.
I've been very happy with my laminated trailer, but actually prefer aluminum due to the lighter weight. At the time I bought mine though, there weren't any aluminum sided hybrids available with a floorplan I liked. (There are now.)
Buy the floorplan you like, then take care of the trailer, and you'll be fine with either one.
Pros for each:
Cons:
44,071 PostsLatest Activity: Aug 23, 2026
