Mike_Up
Aug 16, 2015Explorer
Mickey_D wrote:
We are in Central Texas and get a LOT of hail (State Farm has replaced our 40 year hail resistant roof three times in the last 14 years). Our insurance agent said don't get a tin trailer here because it will just get whooped unless you keep it under something all the time. He said to get a glass one because they hold up a lot better in hail, and if they do get damaged very badly, they total them out and you go get a new one (as well as your home roof).
I have seen several trailers around here that have so many dents from hail that they just look sad, including an airstream that looked like a giant silver golf ball...
Here in NW Indiana, we get Thunderstorms and hail all the time unfortunately. I had hail damage on my previous 2008 Jay Flight 19BH. It had hail damage in 2012. It was not totaled but had significant hail damage.
It was rather easy to fix but parts cost was significant as molding and trim would all have to be replaced as it couldn't be reused with reliability. It was about $4000 for all 4 walls, Labor, and trim pieces. However there was no damage other than cosmetic and it really didn't look that bad. So it didn't have to be repaired at all.
The same can't be said about laminated. I talked to a repairman replacing a whole wall of a laminated trailer because the owner cracked the wall. No it couldn't be fixed right and the wall itself was $4000 and the labor was another $4000 for a grand total of $8000!! Just for a 6" crack (all the way through front skin and backer) in the wall. That was also in 2008 dollars which would had been a lot less expensive than the 2012 dollars that were on the hail damage I had.
So IMO, stick and tin still rules there. Also what about simple mistakes people make. I seen people back into the campsite number pillar and dent their aluminum siding. No repair needed, just an ugly spot. Do that with a laminated trailer wall that doesn't give, you'll be replacing the wall or have a bad attempt at a repair that won't hold and look bad.
Also with 'bad' hail damage, you'll end up breaking all skylites and essentially getting terrible rain water damage in the interior of the camper. Then no matter what walls it has, it may possibly be totaled out.
I'm still saying Stick and Tin is the best choice in 99.5% of situations. Just my take.
44,071 PostsLatest Activity: Aug 23, 2026
