Gdetrailer
Mar 11, 2015Explorer III
Southedistoman wrote:
Out of curiosity, what pump did you end up using? The fill neck on my truck is above the level of the bed, so gravity feed wont work for me.
Correct, since the tank sits below the fuel door I had to use a electric fuel pump..
Ended up buying a Carter P4600HP
HERE
Pumps about 1.2 gal per minute and takes about 11-12 minutes to empty the 15 gallon tank.
You can get higher GPM pumps but they are considerably more expensive.
44,056 PostsLatest Activity: May 04, 2014
