handye9
May 20, 2017Explorer II
You are using your external cable input as an input for over the air antenna signal. You would need to switch the connection from the booster to the cable output to the television. Your television should continue to be set for antenna.
As noted above, your booster is no longer involved and the switch may not improve your reception.
44,071 PostsLatest Activity: Aug 30, 2026
