mike-s
May 20, 2017Explorer II
Unless your TV has 2 different coax inputs labeled cable and air (doubtful), you want to tell it to run on "air," not "cable." To the TV, the difference is what frequencies it scans for, and if an antenna is connected, it's "air."
If you have an RV antenna with an internal jack and switch on a wall plate, you probably want to make sure the switch is off (LED not lit) - that switches between using the RV antenna and the external input.
44,071 PostsLatest Activity: Aug 30, 2026
