MFL
May 21, 2017Nomad II
I often use a Jack antenna on a mast, fastened to my ladder, extended about 4' above my roof. I have coax fastened to cable inlet, on outside. The Jack comes with it's own power up source, plugged in inside. This gives much better range than my omni OTA, which is only good for short range to towers.
Yes, you need tv set to OTA, when using cable inlet, for OTA viewing.
Jerry
Jerry
44,071 PostsLatest Activity: Aug 30, 2026
