Great input from all responders. Since I had the wheel hib removed and the bearings repacked at about 2000 miles and I have less than 6000 easy road miles, I'm doing the EZ Lube process. Got two done in about an hour..the other side I'll do later today when I'm in the shade. One question from this new guy at this..There is some new grease remaining in the cavity behind the rubber seal that covers the zerk fitting. I've wiped it out significantly, but because it is sealed with the rubber cap, can't see that it can go anywhere but within the zerk cavity? What's your take on this?
