martinto wrote:
2011 4 wheel TT with about 6000 miles road miles. Dealer service suggested I just rotate each wheel and add a few pumps of red lithium grease through the zerk fittingnas I turn. I've seen the you tube videos that show a full grease injection pushing out the old grease. I had the bearings repacked at about 2000 road miles. I welcome a sharing of experiences from others.
Dexter's axle / brakes maintenance schedule at:
- click here - For my many boat, utility and RV trailers, I "minimum" remove hubs, do full brake inspections, repack wheel grease "every year" (every spring - after winter damp season). If I tow my trailers, I use their estimated miles traveled as full maintenance task trigger as well. As a DIY task, it only takes 20 minutes to pull each hub and do a full complete inner drum inspection with re-lube. Very easy task.
Note: When one blindly pumps in grease, where does the old grease go? Does its inner pressure blow inner seal and one is now pumping the old grease into its inner brake drum cavity? The only way to safely grease the hubs is to remove it - and do it properly. When while removing the brake hub, do full brake inspection / cleaning as well.
Do it properly or not at all...
