JCK
Jul 06, 2017Explorer
Really bad advice from Bager
The easy lube system is a good system It uses a double lip seal on the axle shaft to prevent grease from entering the brake area. When you grease through the zerk the grease goes through the center of spindle and out a small hole just beyond the inner bearing and before the seal. As you slowly grease and turn wheel the grease is forced through the innner and outer bearing and you will see it coming back at you around the spindle , zerk area then stop . The key thing here is pump slowly and turn the wheel also when pumping . The first time it may require a half tube of grease or more .
44,072 PostsLatest Activity: Aug 23, 2026
