soren
Jul 08, 2017Explorer
BB_TX wrote:
When done correctly the EZ Lube system works fine. I have used mine multiple times and no grease past the seals. Pump slow while continuously turning the wheel until new grease starts coming out the front of the hub exactly as Dexter says and the videos show and it works.
Some people have said they bought a new rig that came with EZ Lube and grease on the brakes showing even the manufacturing person used it incorrectly, probably using a pneumatic grease gun, or pumping a manual gun hard and fast. But often they are paid bonuses for making daily quota numbers and speed is money.
Many who criticize the system have never actually used it themselves.
Many years ago, when these things first came out, they were a sales lizard's dream. I can't count home many times one of those lying belly crawlers looked me in the eye and said, "The axles are now nearly maintenance free. Every spring you give them a few pumps with a grease gun and you are good to go!" Really? How does that manage to visually inspect the drums for cracks, the shoes for even wear, thickness and contamination, the star adjusters for proper tension, the magnets for even wear and function, and the bearings and races for wear and proper lubrication? This list, BTW is what every competent mechanic is doing while repacking bearings.
I have had a new TT with ez-scam axles and grease blown all over a brake drum, right from the factory. I can't even begin to imagine how many trailers are out there with wildly misadjusted brakes and/or grease saturated shoes, since the marketing of ez-scam hubs began?
As for your claim of criticism by the uninformed, I'll offer the opposite. I was asking the owner/chief mechanic of a highly regarded, family run RV dealership why I couldn't find double lip seals in on the shelf at his store. He asked if I did my own work on the trailer? He then told me to buy the regular seals for 1/4 the price, do the job properly, and never pump grease in them. In his experience they are a scam. He does mandated state inspections involving pulling drums, and most regular ez-scam users eventually end up with greasy, compromised brakes.
No, I will concede that this situation exists since 90% of all users fail to follow instructions, and just pump away, on cold bearings, with cold grease, while failing to rotate the rim, but it doesn't really matter. If you are marketing a technique that typically results in greasy brakes and encourages a lack of proper maintenance, IMHO, there is a problem.
44,072 PostsLatest Activity: Aug 23, 2026
