mike-s
Jul 11, 2017Explorer II
RinconVTR wrote:So what? Either can exceed the pressure the seals can handle. The seals aren't made to withstand much pressure, they're there to keep unpressurized grease in place. The common "10-36" single lip seal, which Dexter specs for the 5.2/6k EZ-Lube axles, is only rated to 10 PSI (based on SKF specs for the seal they cross reference).
It takes more effort and pressure to push grease thru a zerk fitting than it does thru the EZlube system!!!!
I couldn't find any good reference, but you claim to know. How much pressure does it take to push grease through the EZ-Lube system, under what conditions, and what's the source of your information?
44,071 PostsLatest Activity: Aug 16, 2026
