LarryJM
Jul 13, 2017Explorer II
Huntindog wrote:
First off, Bearing Budies are a different system than EZ lubes. Bearing buddies are a product for boat trailers, and it actually works as advertised, unlike the EZ lube system.
Here are the facts on how this works.
The zerk feeds a hole that will attempt to grease the inner bearing. How well this will work depends on the condition of the seal/hub interface, and the skill of the person doing it.
He needs to slowly turn the wheel while steadyling pumping the grease... It is working blind as you cannot see what is really going on in there. Is the fresh grease getting evenly distributed in the bearing? Or are spots being missed/skipped? Is the seal really in good shape? or is grease seeping past it onto the brakes?
One simply cannot be sure. All seals age and leak at some point. Sometimes a brand new seal is nicked during installation... Without superman vision, one cannot know.
But the potential problems don't stop there. In order to grease the outer bearing, the grease must travel thru the inner bearing, and the hub cavity to the inside of the outer bearing. This takes a considerable amount of grease... Several tubes each time for a dual axle TT... That's right EACH TIME... The video on Dexters site is misleading. The dirty grease that they show exiting the hub is only from the outer bearing. The dirty grease from the larger inner bearing is still in there some where.... Some of it may have even made it to the inside of the outer bearing!!
Without xray vision, one cannot know exactly where it is... So one must keep pumping and pumping and pumping,, until a second section of dirty grease emerges. Even then one cannot know if all the dirty grease is purged. It is a long trip for the grease, and it probably will not travel evenly around the hub..
With all of the pumping that must be done, a compromised seal will likely fail greasing the brakes... But hey, I hear that well greased brakes never wear out.:B Another caution: There has been at least one report of the grease hole in the spindle that feeds the inner bearing having a burr from being drilled at the factory. This was nicking brand new seals when the drum was installed, and causing the grease to get on the brakes. The fix was an old hot rod trick. Use a dremel to chamfer the hole.
So you see it is not as simple as the marketing makes it out to be.
Now knowing all of the facts, if one still wants to use this "feature" I wish them well.
And visually ....
EZ lube axle exit hole:
Larry
