Mont_G_J
Jul 13, 2017Explorer
I’m puzzled…If EZ lube system Seals fail as frequently as many of you believe they do, then why doesn’t the axle manufacturers use seals like those on every car and truck rear axle that work just fine in keeping the gear fluid from leaking into the drum and on the brake shoes?? How about the front and rear seals on the transmission and engine? I guess what I don’t understand, if you cannot trust EZ lube seals, how can you ever be at peace driving your 400 horsepower tow vehicle knowing the failure of anyone of those seals could result in a repair bill in the thousands?
