mike-s
Jul 13, 2017Explorer II
Mont G&J wrote:Those systems aren't pressurized like an EZ-Lube hub is when pumping grease in. And, the axle seals work just fine if you hand pack the bearings so the seal doesn't experience that pressure. Next question.
why doesn’t the axle manufacturers use seals like those on every car and truck rear axle that work just fine in keeping the gear fluid from leaking
