plasticmasterExplorerJul 06, 2017EZ lube spindle and bearing repack questionMy TT axles have the EZ lube spindles with the grease fitting on the end. It's time for me to repack the bearings. Is it safe to hand pump new grease through the fitting while slowly turning the whe...Show More
falconbrotherExplorer IIDec 18, 2017Don't over grease it using the zerk fitting. On a new trailer one squirt a year is enough, or so says my RV repair guy.
Related ContentSmoked Bearing -- Spindle Damage - Axle Replacement??Wheel bearing repackingtrailer bearing, seal & spindle questionsGreasing bearings questionWheel Bearing Question
