Kevin_O_
Jul 25, 2014Explorer
Hybridhunter wrote:Amen brother!!! :)ah64id wrote:
Yes I am relying on other peoples data, its the data directly from the manufacturer. If that is assumed, well then******I guess nothing is real and everything is assumed.
Very ironic after all your rationalizing and number bending to say that.
The axle weight ratings on most "1/2 tons" are the rating of the spring pack, not the axle itself. Strange you know everything, but were unaware of that facts. And the HD F150 uses a thicker gauge frame, I notice you assumed otherwise....
And a big whoop-de-doo on full vs semi-float axles. You need to get over yourself, and start by not posting your crazy one-dimensional opinions as fact. Not everyone buys their truck to compensate. And just because you are all religious over your vehicle philosophy does not make it correct.
Hey, I was also told that the HD F150 uses a thicker gauge frame.. And I was told that the crewcab F150's with 157" wheelbase use the same thicker gauge frame. So I guess i can "ASSUME" my GVWR is 8200lbs and not really 7700lbs?? :B
