BillyW wrote:
I can't see a problem. If it's rated for the task, and you're not in a hurry...
^This.
When you say std engine and majority of the truck onthe lot, do you mean base V6 or the 5.0?
No experience with the 6 bangers but I've towed a lot of heavy trailers with the 5.0 F150.
Pulling up to 14-15klbs low profile, it worked very well, save for the soft suspension. I put Timbrens on it day 1 and lowered them to almost touching with no load, lol!
I will admit there was a couple times though I dropped the trailer on the side of the road and went home n got my personal truck, in my sig, just due to some ridiculous tongue weight and the tail wagging the dog. It wasn't because the 5.0 couldn't pull or stop the trailer. (With trailer brakes of course).
I've pulled the same stuff with my 6.2 F250 and I believe the 5.0 pulled every bit as well.
The only hi profile trailer I pulled with the 5.0 was a 32' enclosed snow machine trailer, mostly empty at about 4klbs. The 5.0 drug it around easily at highway speeds and had no trouble maintaining 60-70mph up hill at low altitude. In fact I think it would hold a higher gear longer than the 6.2.
If you're looking at V8s, I'd put the 5liter up against any newer gasser out there.......and I'm not even a Ford guy!
