Terryallan wrote:
colliehauler wrote:
I know it's not a direct answer to your question but a friend of mine in Texas bought a new Ford but it had the 3.7 base model. Doing some research the V-6 had more hp then the old 460 during the late 70's. Use to pull all the time with that.
As long as your friend knows the limitations it should work fine.
But. What about the torque of that old 460CI. 385 FT pounds. V6=253. Remember. It's the torque that makes stuff move.
Sort of correct but not really.
Torque at the crank shaft isn't what determines if the stuff will move. It's the torque at the wheel. With the newer transmissions, they are better able to coordinate the gears so you have the torque at the wheels even if the engine doesn't have as much torque.
