Last trip, I noticed my 2012 F150 3.5 ecoboost started to heat up about 5 minutes into a hard climb. Slowed to 60mph and it went back to normal. So I'm looking at having the radiator hot tanked and ...
I pulled one grade in particular that I became a bit "aware" of the temperature. After reading online, apparently these modern engines will heat the coolant up a bit more than older designs. Best I can figure, up to 220-225 is not uncommon and not out of expectations. That said, in the Rockies, I will usually be around 212-215 when climbing.
Edit: sorry, I misunderstood and was thinking tranny temps.
