sarhvac1 wrote:
not sure why you would use anything but Motor-craft oil? factory oil is what is recommended why would you run tractor oil in your truck I have a 7.3 and never run anything but motor craft oil and filters for a couple of bucks extra it's worth piece of mind in my opinion.
From the manual:
Engine oil specifications
To help achieve acceptable engine performance and durability, it is
important that only engine oils of good quality are used in your diesel engine and it is changed at the recommended interval. For normal or severe service, use Motorcraft oil or an equivalent oil conforming to Ford specifications as listed in the Maintenance product specifications and capacities section in this chapter or API service categories CJ-4 or CJ-4/SM. It is important to use these oils because they are compatible with the emission control equipment of your vehicle to meet the more stringent emission standards.
The use of correct oil viscosities for diesel engines is important for
satisfactory operation. Determine which oil viscosity best suits the
temperature range you expect to encounter for the next service interval from the following SAE viscosity grade chart.
