Royals Fan wrote:
Thanks for the feedback!Talked with a gentleman today who had AF 811 on a f-250 short bed,he said air bags and sway bar is what he did.
The 811 is heavier than the 865 you were considering (both will put you over GVWR). I also haul an 811 on a F250, but mine has 1000 lbs more GVWR than yours and plus a number of upgrades to safely handle the weight. Yes you will be able to do this too, but expect about $4000 in upgrades to be able handle this safely. Only you can answer whether you want to spend that much to upgrade your current truck or go to a more capable truck that needs less upgrades.
