SETenn wrote:
I just found out that it does have the hill assist so maybe that is what is going on?? For you guys that have this feature, does it feel like something breaks free when you hit the gas pedal? The previous owner put a level kit on this truck, which I hate, and I'm wondering if dropping the back end a little with the kit causes the hill assist to engage more often than needed.....
I have a 2012 F250 that does the same thing. It is the hill assist thinking you stopped on a hill or maybe you did stop on a slight incline.
Relax, you will get used to it. I don't think you will change a thing by throwing all the stuff at it as suggested by some posts.
Mine has been doing that since new.
A second thought here. If it bothers you you might consider looking in the owners manual and see if it has a fuse. maybe pull it and disable the system, but that may cause a light on the dash. Just a thought.
I also suspect your mechanic needs to bone up a little bit on how that beast works.
