JIMNLIN wrote:
spoon059 wrote:
JIMNLIN wrote:
The 2500 Ram has coils springs on the rear. Not the best for max loads.
My coil springs are rated for 6500 lbs, WAY more than a 10,000 lbs class limited truck needs. Also I've noticed Fords have a saggy suspension with weight, something I haven't seen with the newer Rams. I respectfully disagree with your comment.
Thats fine...My thinking was if the OP was going with a heavy truck camper.
Those that have the 2500 Ram/heavy TC say they have sag and sway issues. BUt if the OP goes with a 12k 5th wheel trailer it should be fine.
Hen you can get the air bag option that will level the truck out. But I’ve yet to hear a complaint from anyone with coil springs on a 3/4 ton.
