spoon059 wrote:
JIMNLIN wrote:
The 2500 Ram has coils springs on the rear. Not the best for max loads.
My coil springs are rated for 6500 lbs, WAY more than a 10,000 lbs class limited truck needs. Also I've noticed Fords have a saggy suspension with weight, something I haven't seen with the newer Rams. I respectfully disagree with your comment.
Standard F250s are soft too. Well, not soft but compliant with light/no load, very similar to how the Ram coils ride.
Sure, both can “handle” a 3000lb load, both barely and doing the Carolina squat.
Point is, none of this matters. Aside from maybe if you’re planning on a truck camper which is not good with the Ram coil design.
All of them can be shored up with suspension adders and being around all 3, all 3 3/4 tons will need something to help once much over a ton in the bed.
Unless you like the Carolina squat look...
