fj12ryder wrote:
I can see there might be some issues with the clearance of the 5th wheel nose and the generator.
And since no one else is asking, I will: What are you planning to do with this setup? Especially 650 lbs. of generator?
Generator is Onan 7000 watt diesel. It's 24 inches wide. So the plan is to install it long ways behind water tank. That will give over 2 feet of clearance for trailer to swing in over chassis. I'm not sure if that's enough. Generator is very economical (at 3500 watt eats 0.5 gallons) and since it wet cooled diesel should last 20000 hours. That's about 7 years of continuous use.
The rig is for boon-docking, my family refuses to conserve water. So sounds like we might have about 600 gallons for 4 people. Hope to last 2 weeks as per BLM 14 day stay rule.
