Plan_B_RV's avatar
Plan_B_RV
F-650 VS International CV
Toy hauler GVW (gross vehicle weight) 20K (with 3,200 lbs. on 5th wheel)
Plus payload of at least 15,900 lbs.
In your opinion, which is better truck if you had only this two trucks to choose from to tow 5th wheel:
F-650:
GVW 29K
GCW (gross combined weight) 50K
Payload 19K
International CV: (AKA Silverado HD 6500)
GVW 22.9K
GCW 37.5K
Payload 15.9K
When fully loaded (that might happen from time to time) International will be over GCW by 2200 lbs.
Both trucks diesel, crew cab but International is 4X4 when f-650 is not.
Bonus question: can you think of any other chassis + crew cab truck that is around GVW 23K (payload of 15K or more)
(Ram 5500 payload around 10.5K and F550 is around 11.5K)
Thank you.
  • 2oldman wrote:
    I'd choose the one with full air ride. They both look like bladder busters.
    International has air suspension from factory and F-650 does not.
  • ib516 wrote:
    How about a used class 8 with a bobbed rear (single rear axle)?
    I was thinking about but my honey said "no way!!!!!!"
  • romore wrote:
    Where are you putting that much weight in addition to the trailer?
    84" Cab to axle chassis gives me 6 feet from cab to 5th wheel hitch. Water is heaviest item, at 8.2 lbs. per gallon.
    Here's picture, approximately what I want but up-fitter will have last word.
  • How about a used class 8 with a bobbed rear (single rear axle)?
  • I'd choose the one with full air ride. They both look like bladder busters.
  • Where are you putting that much weight in addition to the trailer?
