Go back and read the ''links'' I posted.... You guys are confusing the OP!... His F-150 will haul the 6.8 Camplite Truck Camper just fine!
twodownzero wrote:
Nope, but you do need an appropriately sized truck and the TC manufacturers are all liars.
If that was the case, then everyone could file a ''lawsuit''!
twodownzero wrote:
Lance also says my 815 will work on a 1/2 ton.
BUT, Lance didn't say it was
''DESIGNED'' for any 1/2 Ton Trucks like the Livin-Lite Website says.... You said Lance says it will work... ''Will work'' and ''designed'' is different!
twodownzero wrote:
What you should conclude from this is that if the camper manufacturer says that a camper will work on a 1/2 ton, what they really mean is that if your 3/4 ton is a 2wd, regular cab, you're okay, and otherwise, you need a 1 ton truck to carry it.
The manufacturer said the 6.8 Camplite Truck Camper
''is designed'' for ''any 1/2 ton.''.... It don't say it will/might work, it said it was ''DESIGNED'' for 1/2 Ton Trucks!
The 6.8 Camplite Truck Camper ''IS DESIGNED'' for ''ANY'' 1/2 ton, Those trucks would be the ''Ford F-150''.
THE LIGHTEST FULLY SELF CONTAINED SHORT BED TRUCK CAMPER ''MADE FOR A 1/2 TON''!
Camplite 6.8 Ultra Lightweight Aluminum Truck CamperCan you read that ?.... Click on the link and read it if you need to.
wvabeer... Your F-150 would haul the 6.8 just fine!... If you need to, you can install airbags so you can pull trailers, boats etc.. etc..
When I first started hauling my ''hard-side Sunlite TC'', I didn't have airbags... Only reason I installed airbags, was because I went with a larger boat... My Sunlite weighs A LOT more than that 6.8 Camplite, and I haul mine with 2002 F-150 and pull a pontoon.
Call them and talk to them on the phone, and please don't listen to some members on here... They don't know what ''designed means''.
