mosseater
May 31, 2013Explorer II
In mountains, mine spends a LOT of time north of 4000 RPMs. It has no choice. That engine does it's best work between 3800-redline. Let it work, you won't hurt it. I actually prefer it get into the lower gear at the start of the hill so I don't lose momentum and have it downshift halfway up the hill under load. I will either pedal the gas to get it to downshift, or, if it's a longer hill coming up, pull it into 2nd manually to keep it from upshifting before I want to. No need to have all that back and forth shifting. It just wastes power and time and increases heat and wear.
44,056 PostsLatest Activity: Jan 19, 2026
