NWnative wrote:
3.5EB in mine hauls 8000# lbs all over the pacific northwest. Has not missed a beat. Would I like an HD truck....sure......but, the F150 makes a fine towing platform when you stay within the specs......
The ONE issue I find with the small displacement is that engine braking is lacking. Really need to make sure you control your speed before you head down the hill. High RPM's when downshifting and a light tap on the peddle here and there will keep it under control.
The OP does not have the EB. Totally different animal in terms of performance.
