TyroneandGladys wrote:
What is the advantage/disadvantage of a f250 over a f150 if the drivetrain are the same and the tow capacity on both 15,000lbs? Would be used to pull a 27 foot travel trailer not a 5th wheel.
Thanks
What 150 has a tow capacity of 15,000#??
Let's start a list.
Bigger Stronger frame.
Bigger Brakes.
Bigger axles (you can't get the same running gear in a 150 as a 250 period).!
Bigger axles (Full floating NOT semi Floating) this is more bearing surface, and the axle only turns the wheel, the spindle of the axle carries the load.
Keep in mind a 150 Max/Max is just that the Max 150, the 250 is a derated 350!
Just because the truck looks big, doesn't mean it is big where it counts!
Not enough payload to carry either hitch weight. I can't imagine the thrill of towing 15,000# with a 150! :B
Many 150's should be able to tow a 27' TT. It sounds like the 15,000# you are referring to is GCVWR (Gross Combined Vehicle Weight Rating) this is the total weight of the TV and the TT.
