Volkov's avatar
Volkov
F150 vs 250
Considering replacing the old girl - 04 8.1 Yukon XL as her electrical gremlins and module failures are becoming increasingly frequent. Plan 1 had been max payload SCrew with max tow pkg but then saw 250 with 6.2 for about the same $$. Both Lariats.
THe one thing I have not seen discussed (with apologies if my search skills are lacking) is the flip of the significant curb weight difference. It is great that the light weight f150 bumps its tow capacity, but coming in a only 5k#, I stopped to wonder if it might be more prone to being pushed around by the 8000+# I would have behind it. THoughts? Anyone with real life experience with the two?
  • Ductape wrote:
    What percentage of time do you tow. 250 will tow better. And suck fuel.
    We got better gas mileage towing the camper with the F250 than we did with the 150.
    Now non-towing, yes, the F150 was better gas mileage-wise. But not so much that it was a huge difference to the wallet. We wasted more money trying to make the F150 tow better than the difference between the fuel costs.
  • The interesting thing is that the tow rating for the max payload 150 and the Yukon is the same, but the F150 has significantly higher payload. The real difference is the inherent weight of the TV. I wouldn't consider standard f150 for what I am hauling don't worry. Waiting for 2 max payload versions to come in so I can crawl around and really see the differences.
    Should say over 90% of the mileage will be unloaded. Tow 4-5 trips per year and usually less than 2 hour trips.
  • What percentage of time do you tow. 250 will tow better. And suck fuel.
  • 150= p metric tires, semi floating axles, weaker frame, weaker wheels, smaller brakes. 250= LT tires, full floating axles, stronger frame, bigger brakes, stronger wheels. You choose
  • Our original TV was a 2013 F150. Our camper is probably 7500-8000lbs loaded up, closer to 10 if we put the RZR in there. So, within the capacities of the F150. But, it was a nightmare to tow. We live in a windy area, and most of the places we go are windy as well. We had some very scary experiences, the worst of which being when a tour bus and then a semi truck passed us in succession on a 2 lane highway (this was on highway 191 in Wyoming between Rock Springs and Pinedale if anybody is familiar). We had a WD hitch, Equalizer, airbags on the back of the truck... pretty much everything that's recommended to optimize towing. That truck was just too light. (ETA: we also got new tires appropriate for towing, even though the original ones only had 4000 miles on them, still didn't help)
    We upgraded to an F250 and the difference was like night and day. I honestly don't see why anybody would buy an F150 to tow even an average sized trailer if an F250 is an option.
    Side note, I also sometimes drove the F250 to work, 40 miles round trip, when he needed my SUV to park at the airport or go to downtown Denver for work, and it was fine for me to drive and park, even in rush hour traffic. Now we have an F350 DRW and it is not really good as a daily driver. The F250 also held it's value very well, they gave hubs more than he owed on it when he traded it in after a year (we're planning ahead for a 5er).
  • Lowest class curb weight will be less than higher class curb weight...think of
    a pro boxer and their weight classes
    You are comparing a light weight with a heavy weight and wondering why one weighs
    more than the other?
    AKA...comparing a cantaloupe to a water melon...a 10lb sledge to a 16lb...
    Most pickups use the same body/sheetmetal between the the lower class 'half ton' and
    hither class '3/4 ton' and '1 ton'...so they 'look' the same/similar to the
    uninformed
    The real difference is below the sheetmetal bodies and is in the frame, drive
    train, suspension and other components...even the software(s) are different
    Bigger/heavier to manhandle larger trailers during the bad day out there when
    Mr Murphy crosses your path...either you have the right sized or not spot on...no
    time to go back to the store for bigger/better...nor time to re-setup
    On the good days, just about anything can tow anything...
    Yes experience...been there...done that...notice all my trucks in my sig have
    gotten bigger as I've gotten older and wiser...AKA lucky to be alive...
