valhalla360
Jan 29, 2022Navigator
Mike134 wrote:valhalla360 wrote:
Based on the 3.5ecoboost and this being an improvement, it should do great.
But as someone mentioned, payload will likely be your limitation.
Payload should be the similar as a 3.5 Ford raised the GVWR by 300lbs on the power boost models.
The point wasn't to compare ecoboost to powerboost payload but 1/2 ton payloads in general vary wildly. Unless it's changed, even if you get the max trailer package, payloads are not always the same.
Have them pull the actual payload (and get it in writing, if the truck isn't on the lot where you can check the door sticker).
44,071 PostsLatest Activity: Aug 30, 2026
