01tundra
Feb 04, 2022Explorer
Groover wrote:Mike134 wrote:valhalla360 wrote:
Based on the 3.5ecoboost and this being an improvement, it should do great.
But as someone mentioned, payload will likely be your limitation.
Payload should be the similar as a 3.5 Ford raised the GVWR by 300lbs on the power boost models.
It is much easier now to get the Max Payload Package than it used to be and is especially easy on the 4wd Powerboost models. With MPP you should have adequate payload for most campers.
When I spec out a 4wd Lariat with 6.5ft bed and Powerboost MPP comes by default.
According to the Ford website you can not get the max payload option with any trim level with the Powerboost engine.
44,071 PostsLatest Activity: Aug 30, 2026
