chryslermastert's avatar
Jul 12, 2017
f150 xlt good or bad?
looking at a 2013 f150 ecoboost 50k to replace my Jeep Grand Cherokee, I pull a 2015 Viking fq, weight is around 3800 hitch weight is around 400. Jeep does very good pulling just want a little more power, will the ford do it? what should I look for as far as problems on this truck? thanks
  • check out our TT forum also for even more input from actual F150 3.5 EB owners pulling trailers of all sizes.
    Loved my 2011 3.5L Ecoboost.
    Zero problems, but was pulling over 8000# and overloaded the rear axle and hitch receiver. So went bigger when the drive train warranty expired.
    At 50K miles, I wouldn't expect any problems as long as the truck has been well maintained.
    And yes the tow package with integrated brake controller is worth it.
  • I had a 2010 Ford F150 SuperCrew with an 8 cylinder so I can't speak to the Ecoboost aspect of your question but I can let you know about the electronic sway control. Let me tell you... on the day that it kicked in when I was going over a mountain (New Mexico, I think) pass, my 30' Keystone Cougar caught a crosswind, whipped to the right, the truck braked and steered and it was all over before I even had a chance to figure out what happened. It all happened in a second. Yes, I had sway control on the Equalizer hitch, too, but, apparently, the event exceeded what the hitch could handle and the truck fixed it.
    By the way, I had the tow package with the integrated brake controller. Not sure if you get that function without the tow package.
