carlislefamily2ExplorerMay 29, 2020F250 3.73 to 4.30 axle ratioI have a 2017 F250 4x4 crew cab, 160" wheel base, 6.2l gas, 3.73 gear ratio. I am trying to see if having 4.30 axle ratio gears installed will make much difference regarding 5th wheel towing. I noti...Show More
LwiddisNavigatorMay 29, 2020Only smaller 5ers will work well with a 3/4 ton truck. Is that what you want?
Related Content3.73 vs. 4.30 AXLE RATIOInteresting comparison F250 vs F250 - axle ratioChanging Axle Ratio from 3.73 to 4.10 and GCWRF250 6.2 gas Towing heavy with 3.73 rear ??Idle/Drive Ratio
