dodge_guy
Jun 09, 2020Explorer II
jfritz_drfritz wrote:dodge guy wrote:
To those that think that runnng in a lower gear is the same as having a lower ratio, you really don't understand what is going on in a transmission and rear axle? If that was the case then the manuf. would just tell people to tow in "X" gear to tow X amount of weight. Unfortunately it do not work like that. I would much rather spend the money on gears and/or gas than get into a newer diesel!
How about explaining the difference to us?
To make it simple, changing the rear gear ratio to a lower (numerically higher) ratio also effectively changes the ratio of each gear in the transmission. It just like having a longer fulcrum and moving the pivot point. Each gear becomes more efficient. I'm not a teacher so maybe someone's else can explain in depth as a teacher would. I'm just going by common sense thinking! And knowing about physics.
