YellowLightning wrote:
I was able to find an F350 version of the F250 I originally looked at. It has a GVWR of 10700 and a payload of 3720. Is it safe to assume if it was a 11000 GVWR the payload would be 4020? What is the difference between a 10700/11000 GVWR, just the spring rating?
Ford markets 12-13 F350 SRW trucks with different GVWR numbers (10000 gvwr on up to 11500 gvwr)....many times for the same identical truck according to Fords specs. And also comes with a 6340 rawr....6780 rawr and 7230 rawr.
Like all truckers what you look for when buying one for hauling/towing is the truck with the highest axle ratings and RAWR in particular as its carrying all the load.
