RKW
May 27, 2023Explorer II
F250 upgrades
I have a 2015 F250. It's has a 6.5 bed, and it's a diesel. Both of those facts mean that the cargo carrying capacity is diminished compared to a long bed gasser. I haul a 5th wheel and it noticeably s...
rjstractor wrote:RKW wrote:
I have a 2015 F250. It's has a 6.5 bed, and it's a diesel. Both of those facts mean that the cargo carrying capacity is diminished compared to a long bed gasser. I haul a 5th wheel and it noticeably squats the the truck. After reading THIS article, I'm considering changing the suspension block out for a F350 suspension block, and adding air bags. This being the internet its not likely anyone has an opinion on this, but just in case, thoughts anyone?
I agree with the others, many apparent inaccuracies in this article. As we see more articles written using AI technology, we will see fiction becoming truth... but that's a whole 'nother topic. The higher block would help the truck be more level loaded, but airbags would accomplish the same. As far as the larger center diff section goes, IIRC the F250 and F350 SRW diesel models have the same rear axle and the same gear ratio. Also, same frame, brakes, many other parts and pieces. DRW models have options for lower (numerically higher) gear ratios, but those have nothing at all to do with payload. A modern diesel pickup like yours has the power and gearing to easily move huge loads stock out of the box- a fact I'm well aware of as I putt up a mountain pass at 45 mph in my 2000 F250 7.3 diesel moving 20,000 GCW. Your truck would pass me by easily while moving 30K. So, my advice, make sure your tires can take your rear axle weight, and add some bags to level your load.
