minnow wrote:
MFL wrote:
The later model 350s have a 4" riser block on top of the rear axle. The 250 has a 2" block, so yes, the 350 will have less clearance.
I ordered my 250 with heavy duty service suspension. It only squats an inch or so, with about 2,000 lbs over the axle. I am still towing about an inch and a half nose high. I am glad I don't have the 4" block.
Jerry
Jerry, How does the 250 ride with the heavy duty service suspension ? Is there a reason why you went with that instead of the Camper Package ?
I use it mostly for towing, on fairly smooth roads, where it rides like any other truck. Rough RR tracks, potholes, or rough bumpy roads encountered out hunting, it rides like a HD truck, which honestly, is quite rough.
I have 3 constant use leaf springs, and an overload 4th one on the bottom. I did not need the rear stabilizer bar of the Camper pkg, and I have heavier coils on the front too.
Jerry
