minnow's avatar
minnow
F250/350 Rear Squat
Those of you towing with a 10000 lb. or lower fifth wheel and either have a F250 or F350. How much does the pickup bed squat after you get the fiver hitched ? Looking at getting one or the other and I have heard/read that the F250 rear drops 2-3". Thanks !
  • Thanks. The issue I have is that my older truck (2004), the bed is not as high as the new trucks are. Every year they appear to be building them taller. With the current truck I tow dead level and the bed squats very little. A newer F250/F350 is taller and when backing under, would have less than the ideal 6" clearance. But if the new truck squats 2-3", I think I'd gain that clearance back. However don't want so much squat that the front of the truck is pointing skywards either.
  • My 2012 f350 would drop 1.75" in rear with my 1200 pin cougar lite attached and 200 pound hitch.
    With my new toy hauler in around 2750 pin it drops 2" excactly as the spring rate is progressive.
    I did read the 250 without the top overloads that are standard on 350 do appear to sag with 2000 or so in the box?... Can't confirm .
    With a 10,000 trailer you are fine.
    Good luck.
